Disassembling Qingping Air Monitor Lite CGDN1
  1. Disassembling Qingping Air Monitor Lite CGDN1, Remove screen: step 1, image 1 of 3 Disassembling Qingping Air Monitor Lite CGDN1, Remove screen: step 1, image 2 of 3 Disassembling Qingping Air Monitor Lite CGDN1, Remove screen: step 1, image 3 of 3
    • When removing the screen with the suction handle and a jimmy be very careful at the right side of the screen and don't damage the connection like I did (see red circle).
    • Carefully remove the screen towards the front. The screen is glued with some tape (see the orange marker).
    • Maybe use some heat to soften the clue.
    • I used a combination of a suction pad and Jimmy.
  2. Disassembling Qingping Air Monitor Lite CGDN1, Remove screen backing plane: step 2, image 1 of 1
    • 2 Philips screws are holding the backing plane of the screen
  3. Disassembling Qingping Air Monitor Lite CGDN1, Disconnect screen: step 3, image 1 of 3 Disassembling Qingping Air Monitor Lite CGDN1, Disconnect screen: step 3, image 2 of 3 Disassembling Qingping Air Monitor Lite CGDN1, Disconnect screen: step 3, image 3 of 3
    • Lift the small black ledge to remove the flat cable of the screen. Orange circle
  4. Disassembling Qingping Air Monitor Lite CGDN1, Remove main PCB: step 4, image 1 of 2 Disassembling Qingping Air Monitor Lite CGDN1, Remove main PCB: step 4, image 2 of 2
    • Disconnect the flat cable of the touch sensor by lifting the little black ledge, see the orange circle.
    • One screw holding the PCB, green circle
  5. Disassembling Qingping Air Monitor Lite CGDN1, Open the back: step 5, image 1 of 2 Disassembling Qingping Air Monitor Lite CGDN1, Open the back: step 5, image 2 of 2
    • 4 Philips screws hold the back in place.
    • You'll need a very long/narrow bit to reach these screws!
  6. Disassembling Qingping Air Monitor Lite CGDN1, Remove sensors & battery: step 6, image 1 of 1
    • You can slide the complete inner parts to the front.
  7. Disassembling Qingping Air Monitor Lite CGDN1, Dismanteling the PM sensor: step 7, image 1 of 3 Disassembling Qingping Air Monitor Lite CGDN1, Dismanteling the PM sensor: step 7, image 2 of 3 Disassembling Qingping Air Monitor Lite CGDN1, Dismanteling the PM sensor: step 7, image 3 of 3
    • Sensor is held by the 10 pin connector
    • Don't let the springs jump away
    • By slightly bending the cover you can lift the cover from the sensor housing
    • 5 little philips screw hold the sesnor PCB in place. To access the fan connector you have to remove the pcb
rkuijer
145 Reputation
1 Guide authored
One Comment
Thank you for the guide! The part number for a replacement sensor appears to be PMS7003. There are some minor cosmetic differences but it appears to function correctly. I would suggest conducting a calibration routine / making sure the sensor is exposed to exterior air a few times over the next few days.
ironeagl - Reply
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 37
All Time: 193
