Compaq Mini 110 RAM Replacement
  1. Compaq Mini 110 RAM Replacement, Battery: step 1, image 1 of 2 Compaq Mini 110 RAM Replacement, Battery: step 1, image 2 of 2
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
    Ask FixBot
  2. Compaq Mini 110 RAM Replacement: step 2, image 1 of 3 Compaq Mini 110 RAM Replacement: step 2, image 2 of 3 Compaq Mini 110 RAM Replacement: step 2, image 3 of 3
    • Push both tabs inward simultaneously and slide the battery out.
    Ask FixBot
  3. Compaq Mini 110 RAM Replacement, RAM: step 3, image 1 of 2 Compaq Mini 110 RAM Replacement, RAM: step 3, image 2 of 2
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
    Ask FixBot
  4. Compaq Mini 110 RAM Replacement: step 4, image 1 of 1
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
    Ask FixBot
3 other people completed this guide.
alea
1,429 Reputation
14 Guides authored
Cal Poly, Team 22-2, Maness Fall 2010 Member of Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Members
20 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 69
All Time: 6,807
