Disassembling Breville BKC600XL Bottom Covers
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Disassembling Breville BKC600XL Bottom Covers, Bottom Cover #1: step 1, image 1 of 3 Disassembling Breville BKC600XL Bottom Covers, Bottom Cover #1: step 1, image 2 of 3 Disassembling Breville BKC600XL Bottom Covers, Bottom Cover #1: step 1, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
  2. Disassembling Breville BKC600XL Bottom Covers, Black Water Inlet: step 2, image 1 of 2 Disassembling Breville BKC600XL Bottom Covers, Black Water Inlet: step 2, image 2 of 2
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
  3. Disassembling Breville BKC600XL Bottom Covers, Bottom Cover #2: step 3, image 1 of 2 Disassembling Breville BKC600XL Bottom Covers, Bottom Cover #2: step 3, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
  4. Disassembling Breville BKC600XL Bottom Covers, Power Cord: step 4, image 1 of 2 Disassembling Breville BKC600XL Bottom Covers, Power Cord: step 4, image 2 of 2
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
Antonio
120 Reputation
6 Guides authored
Cal Poly, Team 1-3, Propen Fall 2012 Member of Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,838
