Digiland 10.1'' DL1016 Battery Replacement
  1. Careful: steps 1-2 are sourced from a guide that's marked as in-progress.
    Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Remove Backing: step 1, image 1 of 2 Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Remove Backing: step 1, image 2 of 2
    • Use an opening pick and an opening tool to pry the backing off the back of the tablet.
    • You may need some force when doing this and if needed use a metal spudger.
  2. Digiland 10.1'' DL1016 Battery Replacement: step 2, image 1 of 2 Digiland 10.1'' DL1016 Battery Replacement: step 2, image 2 of 2
    • Gently lift the backing off.
  3. Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Disconnect LCD Connectors: step 3, image 1 of 3 Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Disconnect LCD Connectors: step 3, image 2 of 3 Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Disconnect LCD Connectors: step 3, image 3 of 3
    • Pull back the black flaps on the ZIF cable connectors.
    • Pull the ribbon cables out of the connectors.
  4. Careful: step 4 is sourced from a guide that's marked as in-progress.
    Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Remove Battery: step 4, image 1 of 2 Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Remove Battery: step 4, image 2 of 2
    • Use an ESD safe pryer to lift the battery up.
    • There is glue that holds the battery down, so carefully pry it open. You may need to use some force.
  5. Digiland 10.1'' DL1016 Battery Replacement, Battery: step 5, image 1 of 1
    • Once you remove the battery, simply replace the battery with a new one.
Virginia Tapia
386 Reputation
3 Guides authored
Gateway, Team S1-G2, Saknee Fall 2019 Member of Gateway, Team S1-G2, Saknee Fall 2019
GCC-SAKNEE-F19S1G2
4 Members
5 Guides authored
One Comment
Where I can buy this battery ? From the screenshot it looks to be a fit for a Tanoshi 2 in 1 computer
Sergii Prokhorov - Reply
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 13
All Time: 2,149
