Devialet Gemini Ear-pipe metallic grid cleaning
  1. Devialet Gemini Ear-pipe metallic grid cleaning, Remove the eartip: step 1, image 1 of 1
    • Remove the eartip by pulling it.
  2. Devialet Gemini Ear-pipe metallic grid cleaning, Remove the metallic grid: step 2, image 1 of 1
    • Insert horizontally a sharp blade, such as a scalpel or a cutter, within one of the large slits and pull out to remove the metallic grid obstructed by earwax. It is attached with an ultrasound welding method, it should come out rather easily.
  3. Devialet Gemini Ear-pipe metallic grid cleaning, Remove the acoustic mesh from the metallic grid: step 3, image 1 of 1
    • Remove the acoustic mesh using the same sharp blade. The acoustic mesh is solely attached to the grid with a circular double-sided adhesive. Throw away the mesh: it is generally difficult to clean it, and once cleaned, it is impossible to attach it correctly to the grid without risk for the speaker. Clean the remaining earwax.
  4. Devialet Gemini Ear-pipe metallic grid cleaning, Replace the metallic grid: step 4, image 1 of 1
    • Reposition the metal grid on its original location. Press the grid toward the pipe with a flat and rigid tool in order to force the grips to re-integrate the plastic.
This repair should not be done many times on one earbud: while the metal grid will still be solidly attached after one repair, it may not remain firmly after several removal.
If the grid tend to fall, apply a drop of super glue with a toothpick on the periphery of the grid.
6 other people completed this guide.
Johnson Yellow
398 Reputation
1 Guide authored
3 Comments
J'ai légèrement endommagé les grilles car j'ai utilisé un cutter standard. Bee recommande plutôt le scalpel
Pensez à bien remettre les grilles en métals dans la même position qu'initialement ! Coup de marqueur avant le démontage par exemple)
Merci pour le tuto
Eisele Bapt - Reply
Le faite pas cela a fait que mon écouteur ou j’ai effectué l’opération à cessé de fonctionner
Paolo - Reply
Parfait, j’avais des bruits de dauphins et un niveau sonore extrêmement réduit sur mon écouteur gauche, maintenant j’ai récupéré la stéréo ! Il n’y avait pas tant de cerumen que ça mais la couche était très uniforme et faisait probablement une membrane imperméable. J’ai fait un petit bain d’eau savonneuse et j’ai gratouillé la saleté avec une mini-spatule, c’était très satisfaisant !
Eve Redero - Reply
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 107
All Time: 992
