Dell XPS M1530 Hard Drive Replacement
  1. Dell XPS M1530 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Turn the computer upside down with the battery facing you.
    • Turn the computer off and disconnect the charging cable from the computer.
    • Failure to unplug the charging cable may result in electric shock.
  2. Dell XPS M1530 Hard Drive Replacement: step 2, image 1 of 1
    • Push the switch as far to the right as possible to unlock the battery.
  3. Dell XPS M1530 Hard Drive Replacement: step 3, image 1 of 2 Dell XPS M1530 Hard Drive Replacement: step 3, image 2 of 2
    • Remove the battery using two hands and pull it away from the computer.
  4. Dell XPS M1530 Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 Dell XPS M1530 Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
    • Remove the four Phillips #1 screws holding the Hard Drive in place.
    • Four 3.5mm Phillips #1 screws
  5. Dell XPS M1530 Hard Drive Replacement: step 5, image 1 of 2 Dell XPS M1530 Hard Drive Replacement: step 5, image 2 of 2
    • Pull the Hard Drive out gently using the tab. It should provide enough leverage to pull the drive out smoothly.
  6. Dell XPS M1530 Hard Drive Replacement: step 6, image 1 of 2 Dell XPS M1530 Hard Drive Replacement: step 6, image 2 of 2
    • Remove both 3.5mm Phillips #1 screws on either side of the plastic casing.
    • There is a second screw on the other side of the casing.
    • Then gently separate the drive from its casing.
Tyler Scholz
479 Reputation
3 Guides authored
Cal Poly, Team 18-4, Maness Winter 2015 Member of Cal Poly, Team 18-4, Maness Winter 2015
CPSU-MANESS-W15S18G4
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 23
All Time: 2,022
