Dell XPS M1530 Battery Replacement
  1. Dell XPS M1530 Battery Replacement, Battery: step 1, image 1 of 1
    • Turn the computer upside down with the battery facing you.
    • Turn the computer off and disconnect the charging cable from the computer.
    • Failure to unplug the charging cable may result in electric shock.
  2. Dell XPS M1530 Battery Replacement: step 2, image 1 of 1
    • Push the switch as far to the right as possible to unlock the battery.
  3. Dell XPS M1530 Battery Replacement: step 3, image 1 of 2 Dell XPS M1530 Battery Replacement: step 3, image 2 of 2
    • Remove the battery using two hands and pull it away from the computer.
Tyler Scholz
479 Reputation
3 Guides authored
Cal Poly, Team 18-4, Maness Winter 2015 Member of Cal Poly, Team 18-4, Maness Winter 2015
CPSU-MANESS-W15S18G4
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 14
All Time: 1,339
