Dell XPS 13 L321X Mouse pad Replacement
  1. Dell XPS 13 L321X Mouse pad Replacement, Track Pad: step 1, image 1 of 2 Dell XPS 13 L321X Mouse pad Replacement, Track Pad: step 1, image 2 of 2
    • Remove ten 3mm screws from the back cover with a T5 screwdriver.
  2. Dell XPS 13 L321X Mouse pad Replacement: step 2, image 1 of 2 Dell XPS 13 L321X Mouse pad Replacement: step 2, image 2 of 2
    • Disconnect the ribbon cable with a plastic iFixit opening tool, by lifting up the black clip and by pulling the white ribbon off.
    • Pull aside the ribbon cable.
  3. Dell XPS 13 L321X Mouse pad Replacement: step 3, image 1 of 1
    • With a plastic iFixit opeing tool, insert it in between and remove the battery cable.
  4. Dell XPS 13 L321X Mouse pad Replacement: step 4, image 1 of 2 Dell XPS 13 L321X Mouse pad Replacement: step 4, image 2 of 2
    • Use a PH00 size screwdriver to remove the 8 screws that secure the battery.
    • Six 3mm screws.
    • Two 5mm screws.
    • Lift the battery out.
  5. Dell XPS 13 L321X Mouse pad Replacement: step 5, image 1 of 1
    • Disconnect the ribbon cable with a plastic iFixit opening tool by lifting up the black clip and by pulling the white ribbon.
    • Place aside.
  6. Dell XPS 13 L321X Mouse pad Replacement: step 6, image 1 of 3 Dell XPS 13 L321X Mouse pad Replacement: step 6, image 2 of 3 Dell XPS 13 L321X Mouse pad Replacement: step 6, image 3 of 3
    • Remove four 2mm screws with a PH00 screwdriver.
    • Remove the mouse pad.
Finish Line
Ahmad EL Herbawi
499 Reputation
3 Guides authored
USF Tampa, Team S6-G3, Lacy Spring 2017 Member of USF Tampa, Team S6-G3, Lacy Spring 2017
USFT-LACY-S17S6G3
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 813
