Dell XPS 13 L321X Battery Replacement
  1. Dell XPS 13 L321X Battery Replacement, Battery: step 1, image 1 of 2 Dell XPS 13 L321X Battery Replacement, Battery: step 1, image 2 of 2
    • Remove ten 3mm screws from the back cover with a T5 screwdriver.
  2. Dell XPS 13 L321X Battery Replacement: step 2, image 1 of 2 Dell XPS 13 L321X Battery Replacement: step 2, image 2 of 2
    • Disconnect the ribbon cable with a plastic iFixit opening tool by lifting up the black clip and pulling the white ribbon off.
    • Pull aside the ribbon cable.
  3. Dell XPS 13 L321X Battery Replacement: step 3, image 1 of 1
    • Insert a plastic iFixit opening tool in between the port and the wires to remove the battery cable.
  4. Dell XPS 13 L321X Battery Replacement: step 4, image 1 of 2 Dell XPS 13 L321X Battery Replacement: step 4, image 2 of 2
    • Take out 8 silver screws that are holding the battery with a PH00 head screwdriver.
    • Six 3mm screws.
    • Two 5mm screws.
    • Lift the battery out.
Finish Line
6 other people completed this guide.
Ahmad EL Herbawi
499 Reputation
3 Guides authored
USF Tampa, Team S6-G3, Lacy Spring 2017 Member of USF Tampa, Team S6-G3, Lacy Spring 2017
USFT-LACY-S17S6G3
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 10
All Time: 2,614
