Dell Inspiron 1521 Hard Drive Replacement
  1. Dell Inspiron 1521 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Rotate the laptop so its bottom is facing up.
  2. Dell Inspiron 1521 Hard Drive Replacement: step 2, image 1 of 3 Dell Inspiron 1521 Hard Drive Replacement: step 2, image 2 of 3 Dell Inspiron 1521 Hard Drive Replacement: step 2, image 3 of 3
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. Dell Inspiron 1521 Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 Dell Inspiron 1521 Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
    • Locate the four 4 mm Phillips #1 screws that secure the hard drive to the laptop. Each of the screws has a white cylinder next to it.
    • Remove these four screws with a Phillips #1 screwdriver.
  4. Dell Inspiron 1521 Hard Drive Replacement: step 4, image 1 of 3 Dell Inspiron 1521 Hard Drive Replacement: step 4, image 2 of 3 Dell Inspiron 1521 Hard Drive Replacement: step 4, image 3 of 3
    • Once you've made sure all four screws are removed slide the hard drive out with your hand.
3 other people completed this guide.
Rogelio Ordonez
54 Reputation
2 Guides authored
Cal Poly, Team 15-47, Forte Fall 2012 Member of Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 Members
9 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 12
All Time: 3,461
