Dell Inspiron 1521 Bottom Panel Replacement
  1. Dell Inspiron 1521 Bottom Panel Replacement, Battery: step 1, image 1 of 1
    • Rotate the laptop so its bottom is facing up.
  2. Dell Inspiron 1521 Bottom Panel Replacement: step 2, image 1 of 3 Dell Inspiron 1521 Bottom Panel Replacement: step 2, image 2 of 3 Dell Inspiron 1521 Bottom Panel Replacement: step 2, image 3 of 3
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. Dell Inspiron 1521 Bottom Panel Replacement, Bottom Panel: step 3, image 1 of 2 Dell Inspiron 1521 Bottom Panel Replacement, Bottom Panel: step 3, image 2 of 2
    • Locate the thirteen 10 mm Phillips #1 screws securing the bottom panel of the laptop.
    • Remove the thirteen indicated screws with a Phillips #1 screwdriver.
    • With the screws removed you can now remove the panel underneath keyboard.
2 other people completed this guide.
Erik Sanchez
21 Reputation
1 Guide authored
Cal Poly, Team 15-47, Forte Fall 2012 Member of Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 Members
9 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 10
All Time: 1,171
