DR.J Professional HI-04 Motherboard Replacement
  1. DR.J Professional HI-04 Motherboard Replacement, Motherboard: step 1, image 1 of 3 DR.J Professional HI-04 Motherboard Replacement, Motherboard: step 1, image 2 of 3 DR.J Professional HI-04 Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Flip the projector so that the bottom is facing up.
    • Remove the eight 10.0 mm screws with a Phillips #0 screwdriver.
    • The screws are set deep in the holes. Be careful not to drop the screws.
    • Remove the two 20.0 mm screws with a Phillips #0 screwdriver.
  2. DR.J Professional HI-04 Motherboard Replacement: step 2, image 1 of 3 DR.J Professional HI-04 Motherboard Replacement: step 2, image 2 of 3 DR.J Professional HI-04 Motherboard Replacement: step 2, image 3 of 3
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The top case should come off fairly easily but be gentle while removing it.
    • Don't yank the top case off as there are cables attached to the motherboard and the top case.
  3. DR.J Professional HI-04 Motherboard Replacement: step 3, image 1 of 2 DR.J Professional HI-04 Motherboard Replacement: step 3, image 2 of 2
    • Remove the three pieces of tape securing cables.
    • Keep the tape for reassembly.
  4. DR.J Professional HI-04 Motherboard Replacement: step 4, image 1 of 2 DR.J Professional HI-04 Motherboard Replacement: step 4, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the four 15.0 mm screws from the motherboard.
    • Be sure to not drop the screws in the device as they can be difficult to recover.
  5. DR.J Professional HI-04 Motherboard Replacement: step 5, image 1 of 2 DR.J Professional HI-04 Motherboard Replacement: step 5, image 2 of 2
    • Squeeze the tab against the connector, and pull the connector straight out from the socket.
    • The cable will come out easily so do not pull too hard.
  6. DR.J Professional HI-04 Motherboard Replacement: step 6, image 1 of 2 DR.J Professional HI-04 Motherboard Replacement: step 6, image 2 of 2
    • Lift the motherboard from the device.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap of the ZIF connector.
    • Pull the cable from the connector.
  7. DR.J Professional HI-04 Motherboard Replacement: step 7, image 1 of 2 DR.J Professional HI-04 Motherboard Replacement: step 7, image 2 of 2
    • Set down the motherboard safely.
Baron Dutra
825 Reputation
4 Guides authored
UMass Dartmouth, Team 1-5, Petersen Fall 2023 Member of UMass Dartmouth, Team 1-5, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G5
4 Members
5 Guides authored
One Comment
Baron, thanks for the guide. My projector took a tumble and landed right on the back where the input/power plug is. I plugged it back in and the red light turns on, but that's all. I don't hear any loose parts and it definitely wasn't overheated. Any ideas on what it could be? Trying to get the right screwdriver to open it up later this week.
Socev - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 97
