DJI Phantom 2 Vision Plus GPS Signal Improvement Technique
Video Overview
  1. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Case Top Shell: step 1, image 1 of 2 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Case Top Shell: step 1, image 2 of 2
    • Remove the following screws from the underside of the Phantom:
    • Twelve 2.0 mm hex bolts
    • Four Phillips #00 screws
  2. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique: step 2, image 1 of 2 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique: step 2, image 2 of 2
    • Gently lift up the top shell case.
    • Do not attempt to fully remove the top shell. The GPS cable is still attached to the mainboard, avoid lifting the case too high or you may damage this connection.
  3. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: step 3, image 1 of 3 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: step 3, image 2 of 3 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: step 3, image 3 of 3
    • The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
    • Pull the GPS connector straight up out of its socket.
    • Lift the top shell case up and remove it from the body of the Phantom.
4 other people completed this guide.
Sam Goldheart
466,454 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
3 Comments
hello do you still help with phantom drones
George Aguirre - Reply
do you still help with drones/
Isn't it better to connect the aluminium foil to the GPS GND for better isolation?
Bruno Duarte - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 4,617
