DJI Phantom 2 Vision+ Battery Removal
  1. DJI Phantom 2 Vision+ Battery Removal, Remove the battery: step 1, image 1 of 3 DJI Phantom 2 Vision+ Battery Removal, Remove the battery: step 1, image 2 of 3 DJI Phantom 2 Vision+ Battery Removal, Remove the battery: step 1, image 3 of 3
    • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
    • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
3 other people completed this guide.
David Hoyt
4,023 Reputation
43 Guides authored
Cal Poly, Team 25-89, Amido Spring 2010 Member of Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Members
63 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 2,260
