DBPOWER RD-810 Motherboard and LED Bulb Replacement
  1. DBPOWER RD-810 Motherboard and LED Bulb Replacement, Top Cover: step 1, image 1 of 2 DBPOWER RD-810 Motherboard and LED Bulb Replacement, Top Cover: step 1, image 2 of 2
    • Make sure the projector is unplugged before starting
    • Place the projector upside down to access the screws on the bottom.
    • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
  2. DBPOWER RD-810 Motherboard and LED Bulb Replacement: step 2, image 1 of 1
    • Flip the projector over and then remove the cover by lifting it up.
  3. DBPOWER RD-810 Motherboard and LED Bulb Replacement, Motherboard and LED Bulb: step 3, image 1 of 3 DBPOWER RD-810 Motherboard and LED Bulb Replacement, Motherboard and LED Bulb: step 3, image 2 of 3 DBPOWER RD-810 Motherboard and LED Bulb Replacement, Motherboard and LED Bulb: step 3, image 3 of 3
    • Remove the three 6mm PH2 phillips head screws.
    • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
  4. DBPOWER RD-810 Motherboard and LED Bulb Replacement: step 4, image 1 of 3 DBPOWER RD-810 Motherboard and LED Bulb Replacement: step 4, image 2 of 3 DBPOWER RD-810 Motherboard and LED Bulb Replacement: step 4, image 3 of 3
    • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
    • Keep the connector parallel to the mother board to avoid breaking the solder connection.
    • Lift the motherboard up and place it out of the way.
  5. DBPOWER RD-810 Motherboard and LED Bulb Replacement: step 5, image 1 of 3 DBPOWER RD-810 Motherboard and LED Bulb Replacement: step 5, image 2 of 3 DBPOWER RD-810 Motherboard and LED Bulb Replacement: step 5, image 3 of 3
    • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
    • Lift the aluminum heat sink up to remove it from the projector.
    • The motherboard is already removed in this step.
John Russell
914 Reputation
9 Guides authored
USF Tampa, Team S5-G3, Eyestone Spring 2018 Member of USF Tampa, Team S5-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S5G3
3 Members
9 Guides authored
One Comment
I have one of these, and it no longer projects an image. I have 12.1vdc at the motherboard where the positive and negative wire are soldered in.
After de-soldering the wires, I used my bench supply to put 12vdc to the wires, still nothing. If I apply power directly to the COB, the COB will illuminate. What is the silver component held to the heat sink? Mine is labeled ‘Kavass BW-80B 250V 5A’. I have not been able to find ANY documentation for that item to be able to determine what it is, does, or what a suitable replacement might be.
Brian Blake - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,680
