CyberPowerPC RGB 7 Color LED Backlight Replacement
  1. CyberPowerPC RGB 7 Color LED Backlight Replacement, Plastic Casing: step 1, image 1 of 2 CyberPowerPC RGB 7 Color LED Backlight Replacement, Plastic Casing: step 1, image 2 of 2
    • Be sure to unplug the keyboard before starting the disassembly.
    • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
  2. CyberPowerPC RGB 7 Color LED Backlight Replacement: step 2, image 1 of 2 CyberPowerPC RGB 7 Color LED Backlight Replacement: step 2, image 2 of 2
    • Remove the sixteen 5 mm length screws using the Phillips head #2.
    • One of the screws may be located underneath a manufacturer's sticker.
  3. CyberPowerPC RGB 7 Color LED Backlight Replacement: step 3, image 1 of 1
    • Lift up and remove the plastic casing.
  4. CyberPowerPC RGB 7 Color LED Backlight Replacement, LED Backlight: step 4, image 1 of 1
    • Remove the metal backing located directly underneath the white plastic casing.
  5. CyberPowerPC RGB 7 Color LED Backlight Replacement: step 5, image 1 of 1
    • Be careful not to pull too hard on the ribbon cable, as it may break.
    • Disconnect the ribbon cable that connects the LED board to the motherboard.
  6. CyberPowerPC RGB 7 Color LED Backlight Replacement: step 6, image 1 of 1
    • Carefully remove the LED board, which should now come free from the casing.
2 other people completed this guide.
Braydon Lantz
229 Reputation
2 Guides authored
USF Tampa, Team S15-G2, Boczar Spring 2018 Member of USF Tampa, Team S15-G2, Boczar Spring 2018
USFT-BOCZAR-S18S15G2
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 30
All Time: 898
