Creative Nomad Jukebox Zen Display Screen Replacement
  1. Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: step 1, image 1 of 3 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: step 1, image 2 of 3 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: step 1, image 3 of 3
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Display Screen Replacement: step 2, image 1 of 3 Creative Nomad Jukebox Zen Display Screen Replacement: step 2, image 2 of 3 Creative Nomad Jukebox Zen Display Screen Replacement: step 2, image 3 of 3
    • Use the plastic opening tool to open the top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Display Screen Replacement, Screen Cover: step 3, image 1 of 1
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover and remove it.
  4. Creative Nomad Jukebox Zen Display Screen Replacement, Display Screen: step 4, image 1 of 1
    • Using the plastic opening tool to pop the metal tab holding the battery in place.
    • By breaking the sticker, it could void your warranty
  5. Creative Nomad Jukebox Zen Display Screen Replacement: step 5, image 1 of 2 Creative Nomad Jukebox Zen Display Screen Replacement: step 5, image 2 of 2
    • Use the spudger tool to unclip the screens wiring pigtail clipped into the motherboard.
  6. Creative Nomad Jukebox Zen Display Screen Replacement: step 6, image 1 of 2 Creative Nomad Jukebox Zen Display Screen Replacement: step 6, image 2 of 2
    • Use soldering iron to melt the solder used to hold the display screen to the motherboard.
    • Using soldering gun with care as it becomes extremely hot and can cause burns.
  7. Creative Nomad Jukebox Zen Display Screen Replacement: step 7, image 1 of 1
    • Using the spudger tool, gently pry up the corners of the display screen to remove it.
Austin Shaw
101 Reputation
1 Guide authored
IUPUI, Team S4-G5, Baechle Spring 2017 Member of IUPUI, Team S4-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 511
