Gather the necessary tools
1--Soldering Iron
2--Solder
3--DB9 Enclosure. This one is being used here.
4--RS232 to TTL/CMOS converter. alldav.com sells the one used here. Cisco does not recommend or endorse Alldav specifically.
5--Cable w/RJ45 connector on one end Any type of cable with an 8P8C (RJ45) connector could used as long as pins 1,2,7 & 8 are connected. A standard RJ45 cable is being used here.
You will also need wire strippers and possibly a screwdriver (depending on which DB9 enclosure you are using).
Connect to the Console Port. Plug the 8P8C (RJ45) end into the console port. You'll have to lean the unit forward to plug the cable in. It might be a little awkward to do alone. If someone else is available, ask for their assistance. As a last resort, lay the unit down. Ensure you have something soft (like a towel) to lay the unit on.
Configure a Terminal Emulator Session Configure your terminal emulator with the following parameters:
Baud=38400
Data bits=8
Parity=none
Stop bits=1
Flow Control=none
The example uses HyperTerminal for Windows; configuring your terminal emulator may vary slightly.
You should now be at a login prompt when you connect with the terminal emulator.
One Comment
Thanks for this Amazing Blog. It is very informative and helpful for me.
<a href="http://pdfdumps.us/exam/220-801.html">Pass4sure 220-801 dumps</a>
