Coolpix S01 Zoom Trigger Replacement
  1. Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: step 1, image 1 of 3 Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: step 1, image 2 of 3 Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: step 1, image 3 of 3
    • Before starting, make sure the camera is powered off.
    • Take the Hex and PH000 bit to remove a 2mm screw from the left side of the camera.
    • Next, remove the 2mm screw from the right side.
    • Lastly, remove the 3mm screw from the bottom of the camera.
  2. Coolpix S01 Zoom Trigger Replacement: step 2, image 1 of 3 Coolpix S01 Zoom Trigger Replacement: step 2, image 2 of 3 Coolpix S01 Zoom Trigger Replacement: step 2, image 3 of 3
    • Once the two 2mm screws and the 3 mm screw have been removed, use the smallest plastic opening tool and pull up on the sides to reveal the inside of the camera.
    • Be sure to remove the battery before continuing your repair.
  3. Coolpix S01 Zoom Trigger Replacement: step 3, image 1 of 2 Coolpix S01 Zoom Trigger Replacement: step 3, image 2 of 2
    • After the battery is out, remove the gray button bar from the top of the camera with the smallest opening tool.
    • With the gray bar detached from the camera, turn it upside down. With the Hex and the J000 bit remove the two 1mm screws.
  4. Coolpix S01 Zoom Trigger Replacement: step 4, image 1 of 2 Coolpix S01 Zoom Trigger Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Take the needle nose tweezers to remove the black ring in the middle of the button.
    • You have successfully removed the zoom trigger and can replace with a new one if needed.
    • To reassemble follow steps in reverse.
angelica fitzgerald
216 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 14
All Time: 328
