Contour Roam2 Rotating Lens Replacement
  1. Contour Roam2 Rotating Lens Replacement, Rotating Lens: step 1, image 1 of 1
    • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
    • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
  2. Contour Roam2 Rotating Lens Replacement: step 2, image 1 of 2 Contour Roam2 Rotating Lens Replacement: step 2, image 2 of 2
    • Rotate the metal ring counterclockwise until completely removed.
  3. Contour Roam2 Rotating Lens Replacement: step 3, image 1 of 1
    • Use a spudger to pry up the black rubber ring around the lens cover.
    • The black rubber ring is vey thin and can easily tear. Use caution when removing.
  4. Contour Roam2 Rotating Lens Replacement: step 4, image 1 of 1
    • Remove and replace the lens cover.
Matthew Kofsky
548 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 837
