Compaq Presario v2000 Hard drive Replacement
  1. Compaq Presario v2000 Hard drive Replacement, Hard drive: step 1, image 1 of 1
    • Remove the battery before starting
  2. Compaq Presario v2000 Hard drive Replacement: step 2, image 1 of 2 Compaq Presario v2000 Hard drive Replacement: step 2, image 2 of 2
    • Loosen the two screw for the hard drive cover
    • The screws will stay attached the the cover
    • Lift the cover from the left side and remove
  3. Compaq Presario v2000 Hard drive Replacement: step 3, image 1 of 2 Compaq Presario v2000 Hard drive Replacement: step 3, image 2 of 2
    • Lift the black pull tab on the hard drive
    • Lift the drive straight up out of the laptop
  4. Compaq Presario v2000 Hard drive Replacement: step 4, image 1 of 2 Compaq Presario v2000 Hard drive Replacement: step 4, image 2 of 2
    • Remove the four screws on the sides of the drive (two on each side)
    • Remove the hard drive from the caddy
  5. Compaq Presario v2000 Hard drive Replacement: step 5, image 1 of 1
    • Pull the IDE connecter straight off the drive
    • Be sure to pull the connecter off straight so as not to bend the hard drive IDE pins
4 other people completed this guide.
Andrew
1,341 Reputation
5 Guides authored
One Comment
Perfect instructions....easy directions even for a computer dunce like me...
John Platania - Reply
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 54
All Time: 9,956
