Compaq Presario CQ62 Hard Drive Replacement
  1. Compaq Presario CQ62  Hard Drive Replacement, Battery: step 1, image 1 of 2 Compaq Presario CQ62  Hard Drive Replacement, Battery: step 1, image 2 of 2
    • It is advised to work on this device only when it is OFF, to avoid electrocution risks. Please make sure your laptop is powered off.
    • On the underside of the battery, there is lock that keeps the battery in place. Using your finger, slide the battery lock to unlock the battery. When you have unlocked it, just lift the battery to remove it.
    • We do not have a battery on our device to show how to take it off.
  2. Compaq Presario CQ62  Hard Drive Replacement, Hard Drive: step 2, image 1 of 2 Compaq Presario CQ62  Hard Drive Replacement, Hard Drive: step 2, image 2 of 2
    • Loosen the two M2.5x3 mm Phillips screws securing the hard drive cover.
  3. Compaq Presario CQ62  Hard Drive Replacement: step 3, image 1 of 1
    • On the same side as the two screws, there should now be an opening to lift off the cover. Using a plastic opening tool, sightly lift the case up to remove it.
  4. Compaq Presario CQ62  Hard Drive Replacement: step 4, image 1 of 2 Compaq Presario CQ62  Hard Drive Replacement: step 4, image 2 of 2
    • Remove the three M2.5x5 mm Phillips screws securing the hard drive assembly.
  5. Compaq Presario CQ62  Hard Drive Replacement: step 5, image 1 of 1
    • Our laptop did not have a hard drive, so it is not included in the photo.
    • To remove the hard drive, detach it from the the hard drive connector. You can do this by pulling it gently with your hands.
Roth Marcelin
726 Reputation
6 Guides authored
USF Tampa, Team 2-6, Sullivan Fall 2016 Member of USF Tampa, Team 2-6, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G6
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 10
Past 30 Days: 33
All Time: 2,997
