Compaq Presario CQ60-211DX Solid State Drive Replacement
  1. Compaq Presario CQ60-211DX Solid State Drive Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop off and disconnect all sources of power.
    • Set the laptop on a flat surface with the bottom side facing up.
  2. Compaq Presario CQ60-211DX Solid State Drive Replacement: step 2, image 1 of 3 Compaq Presario CQ60-211DX Solid State Drive Replacement: step 2, image 2 of 3 Compaq Presario CQ60-211DX Solid State Drive Replacement: step 2, image 3 of 3
    • Slide the battery release tab.
    • This will eject the battery.
    • Carefully remove the battery and set it aside.
  3. Compaq Presario CQ60-211DX Solid State Drive Replacement, Solid State Drive (SSD): step 3, image 1 of 2 Compaq Presario CQ60-211DX Solid State Drive Replacement, Solid State Drive (SSD): step 3, image 2 of 2
    • Use a PH1 screwdriver to unscrew the 2 screws that secure the hard drive cover.
    • Remove the cover.
  4. Compaq Presario CQ60-211DX Solid State Drive Replacement: step 4, image 1 of 2 Compaq Presario CQ60-211DX Solid State Drive Replacement: step 4, image 2 of 2
    • Unscrew the next three screws holding the hard drive in place.
    • Pull the black ribbon and slide the hard drive out of place.
Garrett Carter
471 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 1,012
