Compaq Presario CQ60 Motherboard Replacement
  1. Compaq Presario CQ60 Motherboard Replacement, Slide battery latch: step 1, image 1 of 2 Compaq Presario CQ60 Motherboard Replacement, Slide battery latch: step 1, image 2 of 2
    • Slide battery latch to left
    • Simultaneously lift battery
  2. Compaq Presario CQ60 Motherboard Replacement: step 2, image 1 of 3 Compaq Presario CQ60 Motherboard Replacement: step 2, image 2 of 3 Compaq Presario CQ60 Motherboard Replacement: step 2, image 3 of 3
    • Lift and remove battery
  3. Compaq Presario CQ60 Motherboard Replacement, Remove hard drive cover: step 3, image 1 of 1
    • Loosen 2 phillips screws
    • Lift and remove cover
  4. Compaq Presario CQ60 Motherboard Replacement, Remove drive caddy: step 4, image 1 of 3 Compaq Presario CQ60 Motherboard Replacement, Remove drive caddy: step 4, image 2 of 3 Compaq Presario CQ60 Motherboard Replacement, Remove drive caddy: step 4, image 3 of 3
    • Remove 3 M2.5x4mm screws
    • Slide caddy forwards
    • Lift tab to remove caddy
  5. Compaq Presario CQ60 Motherboard Replacement: step 5, image 1 of 1
    • Remove 4 phillips screws to remove drive from caddy
  6. Compaq Presario CQ60 Motherboard Replacement, Unscrew keyboard: step 6, image 1 of 2 Compaq Presario CQ60 Motherboard Replacement, Unscrew keyboard: step 6, image 2 of 2
    • Remove 3x M2.5x4mm
  7. Compaq Presario CQ60 Motherboard Replacement, Lift keyboard: step 7, image 1 of 3 Compaq Presario CQ60 Motherboard Replacement, Lift keyboard: step 7, image 2 of 3 Compaq Presario CQ60 Motherboard Replacement, Lift keyboard: step 7, image 3 of 3
    • Lift the keyboard in the middle with a spudger
    • Remove 4 clips by bending keyboard in middle, do not force the clips at the sides
    • Do not remove the keyboard fully, it is attached via a ribbon cable
  8. Compaq Presario CQ60 Motherboard Replacement, Detach ribbon cable: step 8, image 1 of 3 Compaq Presario CQ60 Motherboard Replacement, Detach ribbon cable: step 8, image 2 of 3 Compaq Presario CQ60 Motherboard Replacement, Detach ribbon cable: step 8, image 3 of 3
    • Lift keyboard slightly
    • Push each side of ribbon cable connector
    • Fully remove keyboard
  9. Compaq Presario CQ60 Motherboard Replacement, Remove screws: step 9, image 1 of 3 Compaq Presario CQ60 Motherboard Replacement, Remove screws: step 9, image 2 of 3 Compaq Presario CQ60 Motherboard Replacement, Remove screws: step 9, image 3 of 3
    • Remove 2x Phillips M2.5x8mm screws from under the display
    • Remove 4x Phillips M2x2.8mm screws from the battery compartment
  10. Compaq Presario CQ60 Motherboard Replacement, Disconnect ribbon cable: step 10, image 1 of 3 Compaq Presario CQ60 Motherboard Replacement, Disconnect ribbon cable: step 10, image 2 of 3 Compaq Presario CQ60 Motherboard Replacement, Disconnect ribbon cable: step 10, image 3 of 3
    • Turn over the laptop
    • Use a spudger to lift the ribbon cable hinged clip
    • Pull the ribbon cable out of the connector
  11. Compaq Presario CQ60 Motherboard Replacement: step 11, image 1 of 2 Compaq Presario CQ60 Motherboard Replacement: step 11, image 2 of 2
    • Lifting the bezel by the screen
    • Slide the bezel back towards the screen to release it from the clips
  12. Compaq Presario CQ60 Motherboard Replacement, Remove bezel: step 12, image 1 of 1
    • Fully remove bezel
  13. Compaq Presario CQ60 Motherboard Replacement, Remove screws: step 13, image 1 of 2 Compaq Presario CQ60 Motherboard Replacement, Remove screws: step 13, image 2 of 2
    • Remove 4x #1 Phillips M2.5x8mm screws from the bottom case
    • Remove 2x #0 Phillips M2x4mm screws from hard drive bay
  14. Compaq Presario CQ60 Motherboard Replacement, Disconnect mouse ribbon cable: step 14, image 1 of 2 Compaq Presario CQ60 Motherboard Replacement, Disconnect mouse ribbon cable: step 14, image 2 of 2
    • Using a spudger lift the mouse ribbon cabe latch
    • Do not remove yet
  15. Compaq Presario CQ60 Motherboard Replacement: step 15, image 1 of 2 Compaq Presario CQ60 Motherboard Replacement: step 15, image 2 of 2
    • Remove 4x #1 Phillips M2x5mm
    • Remove 1x #0 Phillips M2x2.6
  16. Compaq Presario CQ60 Motherboard Replacement: step 16, image 1 of 2 Compaq Presario CQ60 Motherboard Replacement: step 16, image 2 of 2
    • Starting at the edge by the screen, use a spudger to unclip the top case
    • Work around both sides and finish with the touchpad
  17. Compaq Presario CQ60 Motherboard Replacement: step 17, image 1 of 2 Compaq Presario CQ60 Motherboard Replacement: step 17, image 2 of 2
    • Lift top base off of laptop, being careful to disconnect the touchpad ribbon cable
  18. Compaq Presario CQ60 Motherboard Replacement, Motherboard: step 18, image 1 of 2 Compaq Presario CQ60 Motherboard Replacement, Motherboard: step 18, image 2 of 2
    • Disconnect CMOS battery backup connector from bottom of laptop
  19. Compaq Presario CQ60 Motherboard Replacement: step 19, image 1 of 2 Compaq Presario CQ60 Motherboard Replacement: step 19, image 2 of 2
    • Disconnect speaker connector. This connector is easy to break, there are 2 tabs on the bottom that need to be lifted slightly to remove. Use a spudger carefully under the connector to lift slightly and pull gently on the wires all together to remove.
    • Disconnect the USB connector
  20. Compaq Presario CQ60 Motherboard Replacement: step 20, image 1 of 2 Compaq Presario CQ60 Motherboard Replacement: step 20, image 2 of 2
    • Remove 2x #1 Phillips M2.5x4.5mm screws holding the optical drive connector
    • Remove the modem port connector
  21. Compaq Presario CQ60 Motherboard Replacement: step 21, image 1 of 3 Compaq Presario CQ60 Motherboard Replacement: step 21, image 2 of 3 Compaq Presario CQ60 Motherboard Replacement: step 21, image 3 of 3
    • Lift audio/status light connector tab using a spudger and remove ribbon cable
  22. Compaq Presario CQ60 Motherboard Replacement: step 22, image 1 of 3 Compaq Presario CQ60 Motherboard Replacement: step 22, image 2 of 3 Compaq Presario CQ60 Motherboard Replacement: step 22, image 3 of 3
    • Remove 1x #0 Phillips M2x2.8mm screw from left speaker
    • Lift speaker out and place out of the way of the motherboard
  23. Compaq Presario CQ60 Motherboard Replacement: step 23, image 1 of 2 Compaq Presario CQ60 Motherboard Replacement: step 23, image 2 of 2
    • Remove 4x #1 Phillips M2.5x4mm screws
  24. Compaq Presario CQ60 Motherboard Replacement: step 24, image 1 of 3 Compaq Presario CQ60 Motherboard Replacement: step 24, image 2 of 3 Compaq Presario CQ60 Motherboard Replacement: step 24, image 3 of 3
    • Lift motherboard from right hand side and slide towards right
    • Be careful of power connector releasing from case
  25. Compaq Presario CQ60 Motherboard Replacement: step 25, image 1 of 2 Compaq Presario CQ60 Motherboard Replacement: step 25, image 2 of 2
    • Motherboard (with RAM) is removed
Mike B
1,018 Reputation
9 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 38
All Time: 1,250
