Compaq Presario CQ60 Keyboard Bezel Replacement
  1. Compaq Presario CQ60 Keyboard Bezel Replacement, Slide battery latch: step 1, image 1 of 2 Compaq Presario CQ60 Keyboard Bezel Replacement, Slide battery latch: step 1, image 2 of 2
    • Slide battery latch to left
    • Simultaneously lift battery
  2. Compaq Presario CQ60 Keyboard Bezel Replacement: step 2, image 1 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement: step 2, image 2 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement: step 2, image 3 of 3
    • Lift and remove battery
  3. Compaq Presario CQ60 Keyboard Bezel Replacement, Unscrew keyboard: step 3, image 1 of 2 Compaq Presario CQ60 Keyboard Bezel Replacement, Unscrew keyboard: step 3, image 2 of 2
    • Remove 3x M2.5x4mm
  4. Compaq Presario CQ60 Keyboard Bezel Replacement, Lift keyboard: step 4, image 1 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Lift keyboard: step 4, image 2 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Lift keyboard: step 4, image 3 of 3
    • Lift the keyboard in the middle with a spudger
    • Remove 4 clips by bending keyboard in middle, do not force the clips at the sides
    • Do not remove the keyboard fully, it is attached via a ribbon cable
  5. Compaq Presario CQ60 Keyboard Bezel Replacement, Detach ribbon cable: step 5, image 1 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Detach ribbon cable: step 5, image 2 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Detach ribbon cable: step 5, image 3 of 3
    • Lift keyboard slightly
    • Push each side of ribbon cable connector
    • Fully remove keyboard
  6. Compaq Presario CQ60 Keyboard Bezel Replacement, Remove screws: step 6, image 1 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Remove screws: step 6, image 2 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Remove screws: step 6, image 3 of 3
    • Remove 2x Phillips M2.5x8mm screws from under the display
    • Remove 4x Phillips M2x2.8mm screws from the battery compartment
  7. Compaq Presario CQ60 Keyboard Bezel Replacement, Disconnect ribbon cable: step 7, image 1 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Disconnect ribbon cable: step 7, image 2 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Disconnect ribbon cable: step 7, image 3 of 3
    • Turn over the laptop
    • Use a spudger to lift the ribbon cable hinged clip
    • Pull the ribbon cable out of the connector
  8. Compaq Presario CQ60 Keyboard Bezel Replacement: step 8, image 1 of 2 Compaq Presario CQ60 Keyboard Bezel Replacement: step 8, image 2 of 2
    • Lifting the bezel by the screen
    • Slide the bezel back towards the screen to release it from the clips
  9. Compaq Presario CQ60 Keyboard Bezel Replacement, Remove bezel: step 9, image 1 of 1
    • Fully remove bezel
Mike B
1,018 Reputation
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 228
