Compaq Presario CQ58 Cooling / FAN system cleaning
Video Overview
  1. Compaq Presario CQ58 Cooling / FAN system cleaning, Cooling / FAN system cleaning: step 1, image 1 of 3 Compaq Presario CQ58 Cooling / FAN system cleaning, Cooling / FAN system cleaning: step 1, image 2 of 3 Compaq Presario CQ58 Cooling / FAN system cleaning, Cooling / FAN system cleaning: step 1, image 3 of 3
    • Switch-off the laptop and remove the battery.
    • Remove the memory cover.
  2. Compaq Presario CQ58 Cooling / FAN system cleaning: step 2, image 1 of 3 Compaq Presario CQ58 Cooling / FAN system cleaning: step 2, image 2 of 3 Compaq Presario CQ58 Cooling / FAN system cleaning: step 2, image 3 of 3
    • Remove the HDD cover.
    • Unpin the HDD.
  3. Compaq Presario CQ58 Cooling / FAN system cleaning: step 3, image 1 of 3 Compaq Presario CQ58 Cooling / FAN system cleaning: step 3, image 2 of 3 Compaq Presario CQ58 Cooling / FAN system cleaning: step 3, image 3 of 3
    • Near to the WiFi card you can see one screw hole with a keyboard symbol. This screw holds the Keyboard.
    • To remove the Keyboard, you must open 5X locking clips.
  4. Compaq Presario CQ58 Cooling / FAN system cleaning: step 4, image 1 of 3 Compaq Presario CQ58 Cooling / FAN system cleaning: step 4, image 2 of 3 Compaq Presario CQ58 Cooling / FAN system cleaning: step 4, image 3 of 3
    • Under the Keyboard there are:
    • 4x M2.5x5.0 screws
    • Mouse flex cable connector
    • Power On button flex cable connector.
    • Unscrew the screws on the bottom side of the laptop:
    • 13x M2.5x5.0
    • 3x M2.5x3.0
  5. Compaq Presario CQ58 Cooling / FAN system cleaning: step 5, image 1 of 3 Compaq Presario CQ58 Cooling / FAN system cleaning: step 5, image 2 of 3 Compaq Presario CQ58 Cooling / FAN system cleaning: step 5, image 3 of 3
    • Use a plastic tool to separate and remove the upper case.
    • Unscrew 5x screws and disconnect:
    • LCD Display cable
    • Additional USB board cable
    • Power jack cable
    • Loudspeaker cable
    • SATA HDD cable
  6. Compaq Presario CQ58 Cooling / FAN system cleaning: step 6, image 1 of 3 Compaq Presario CQ58 Cooling / FAN system cleaning: step 6, image 2 of 3 Compaq Presario CQ58 Cooling / FAN system cleaning: step 6, image 3 of 3
    • Move a little the LCD display hinge.
    • Remove the board by starting from the right side.
  7. Compaq Presario CQ58 Cooling / FAN system cleaning: step 7, image 1 of 3 Compaq Presario CQ58 Cooling / FAN system cleaning: step 7, image 2 of 3 Compaq Presario CQ58 Cooling / FAN system cleaning: step 7, image 3 of 3
    • Remove the cooling system.
  8. Compaq Presario CQ58 Cooling / FAN system cleaning: step 8, image 1 of 2 Compaq Presario CQ58 Cooling / FAN system cleaning: step 8, image 2 of 2
    • Open the fan and clean the dust from inside with a soft brush.
  9. Compaq Presario CQ58 Cooling / FAN system cleaning: step 9, image 1 of 3 Compaq Presario CQ58 Cooling / FAN system cleaning: step 9, image 2 of 3 Compaq Presario CQ58 Cooling / FAN system cleaning: step 9, image 3 of 3
    • Clean the old thermal compound (from the CPU and from the heat-sink system).
    • Put a new thermal compound and start with reassembling.
  10. Compaq Presario CQ58 Cooling / FAN system cleaning: step 10, image 1 of 3 Compaq Presario CQ58 Cooling / FAN system cleaning: step 10, image 2 of 3 Compaq Presario CQ58 Cooling / FAN system cleaning: step 10, image 3 of 3
    • When you start the system, check that fan is working.
    • Did you do it successfully?
9 other people completed this guide.
ZFix
191,507 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,487 Guides authored
7 Comments
A brilliant demonstration really clear and well photographed, only one problem how the !&&* do you get the screws undone mine seem fixed solid
please let me into the secret if there is one.
thanks for the demo anyway.
JF.
alma francomb - Reply
Thanks for this!
My Son and I have just successfully removed, cleaned and replaced the fan in his laptop by following the instructions above.
Great work.
David Cooper - Reply
Thank you a lot !!!!
lone guldbæk kvist - Reply
I think i did something wrong? I completed all the steps but my fan (which is brand new) keeps making this scary loud wizzy noise instead of a hum and did i not tightem the screws enough or they to tight?? Please help!
Layla - Reply
Please ensure the fan metal case is not bent and ensure the fan is properly mounted. If this doesn’t solve your problem, your new fan is defective.
Brendan -
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 66
All Time: 24,772
