Coby DVD-R11000 Outer Casing Replacement
  1. Coby DVD-R11000 Outer Casing Replacement, Outer Casing: step 1, image 1 of 3 Coby DVD-R11000 Outer Casing Replacement, Outer Casing: step 1, image 2 of 3 Coby DVD-R11000 Outer Casing Replacement, Outer Casing: step 1, image 3 of 3
    • Remove the four 1cm screws, two on each side, of the DVD player with the Phillips #1 screwdriver.
    • Remove the five 1cm screws on the back of the DVD player with the Phillips #1 screwdriver.
    • It is not required to remove the other seven screws in the middle between the I/O ports.
  2. Coby DVD-R11000 Outer Casing Replacement: step 2, image 1 of 3 Coby DVD-R11000 Outer Casing Replacement: step 2, image 2 of 3 Coby DVD-R11000 Outer Casing Replacement: step 2, image 3 of 3
    • Position the DVD player so that the back is facing you
    • Grab underneath the sides of the DVD player and lift the front of it upwards.
    • Carefully pull the top of the casing off
Andrew
501 Reputation
5 Guides authored
UMass Dartmouth, Team 1-6, Shastany Fall 2014 Member of UMass Dartmouth, Team 1-6, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G6
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 148
