Cleaning Panasonic NB-G110P Toaster Oven Power Switch
  1. Cleaning Panasonic NB-G110P Toaster Oven Power Switch, Remove the Switch Button: step 1, image 1 of 1
    • Before starting this guide make sure the toaster oven is unplugged.
    • If the switch still works and isn't failing yet, simply try cleaning it.
    • Pry off the grey plastic on-off button to expose the head of the on/off switch.
    • Apply some electrical contact cleaner (CorrosionX or MG Chemicals Super Contact Cleaner or something similar) or, less ideally, 91% or better isopropyl alcohol to the switch.
    • Work the switch a bit by turning it on and off a lot (still unplugged) and see if that doesn't fix the problem.
  2. Cleaning Panasonic NB-G110P Toaster Oven Power Switch, If Cleaning Doesn't Work (or Stops Working): step 3, image 1 of 1
Fixit Clinic
670 Reputation
2 Guides authored
Global Fixers Member of Global Fixers
Community
33 Members
582 Guides authored
One Comment
I cleaned my switch…it works great now! Thank you!!!!
Thea G - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 989
