How to clean Nikon N2000 (F301) battery corrosion
    • In this guide we will be referring to 'left'and 'right' as though the camera's front (the part that says Nikon) facing you.
    • Use a quarter to twist open the one large screw on the bottom case. (No picture available.)
  1. How to clean Nikon N2000 (F301) battery corrosion: step 2, image 1 of 1
    • Pull up on the tab to remove the batteries.
    • Note: The batteries will probably fall out of their holder.
  2. How to clean Nikon N2000 (F301) battery corrosion: step 3, image 1 of 1
    • Your camera should look something like this.
    • Clean the marked areas with a cotton swab soaked in CLR or vinegar.
  3. How to clean Nikon N2000 (F301) battery corrosion: step 4, image 1 of 1
    • Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
  4. How to clean Nikon N2000 (F301) battery corrosion: step 5, image 1 of 1
    • All cleaned up!
Reinsert the batteries by following the instructions backwards. If it's still not getting power, head over to our battery compartment replacement guide. Note: It may be tough to find replacement parts.
3 other people completed this guide.
Zachary Phillips
247 Reputation
5 Guides authored
Cal Poly, Team 25-26, Garner Spring 2011 Member of Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Members
12 Guides authored
2 Comments
Wow it working thanks for assisting me. I used vinegar to clean my camera so it working now
lazarusmolai - Reply
Thumb down! Step 5 says, “All cleaned up!” But the picture shows much corrosion still present. Asking for further problems! Look up: "Nintendo Gameboy Pocket Shell-Side Battery Terminal CorrosionRemoval” for tips how to do it more thoroughly.
Wolf Naegeli - Reply
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 73
All Time: 15,675
