Chromo Noria Camera Replacement
  1. Chromo Noria Camera  Replacement, Back Panel: step 1, image 1 of 3 Chromo Noria Camera  Replacement, Back Panel: step 1, image 2 of 3 Chromo Noria Camera  Replacement, Back Panel: step 1, image 3 of 3
    • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
    • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
  2. Chromo Noria Camera  Replacement: step 2, image 1 of 1
    • Carefully turn the device over.
    • Lay the back panel aside so you can see the device's parts.
  3. Chromo Noria Camera  Replacement, Camera: step 3, image 1 of 2 Chromo Noria Camera  Replacement, Camera: step 3, image 2 of 2
    • Carefully detach one side of the black tape from the board.
  4. Chromo Noria Camera  Replacement: step 4, image 1 of 2 Chromo Noria Camera  Replacement: step 4, image 2 of 2
    • Using a small plastic opening tool, flip the black connector up until it makes "tick" sound.
    • Now, the flexing cable is ready to be removed.
  5. Chromo Noria Camera  Replacement: step 5, image 1 of 2 Chromo Noria Camera  Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Using a pair of tweezers, hold the flexing cable right below the black connector.
    • Gently pull the flexing cable out of the connector while balancing the other side of the device with another hand.
Ryan Rho
201 Reputation
2 Guides authored
Baylor, Team 5-6, Williams Fall 2016 Member of Baylor, Team 5-6, Williams Fall 2016
BU-WILLIAMS-F16S5G6
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 124
