This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Moto G30 screen replacement
    • Remove the SIM card tray with a pin or a pointy object
  1. Moto G30 screen replacement, Unclip the back cover: step 2, image 1 of 1
    • Unclip the plastic back cover using any tool you like (mediators, sprudgers, Jimmy...)
    • Be careful not to lift the cover too far from the phone, it has to be lifted cautiously because a cable is attached to it
  2. Moto G30 screen replacement, Unscrew the optical cover part: step 3, image 1 of 2 Moto G30 screen replacement, Unscrew the optical cover part: step 3, image 2 of 2
    • Slighly move the back cover in order to unscrew the plastic piece behind it
    • You will find 9 small Philips-head screws
    • You will also have to remove small black adhesive pieces to be able to remove the part completely
  3. Moto G30 screen replacement, Free the back panel: step 4, image 1 of 1
    • Once the black plastic cover piece is removed, it is possible to unplug the cable holding the back panel
    • Once this flex cable unplugged, lift the back panel completely
  4. Moto G30 screen replacement, Unplug battery and screen: step 5, image 1 of 1
    • Unplug both battery and display connectors (battery on the right and display in the middle). You can use the opening tool as lever.
  5. Moto G30 screen replacement, Unglue the battery: step 6, image 1 of 1
    • Very carefully unglue the battery
    • Adhesive is quite strong here, and the battery is not very rigid, so this is a complicated operation. It would be dangerous to head the battery cell, be patient and careful.
  6. Moto G30 screen replacement, Unplug bottom-side cable: step 7, image 1 of 1
    • Unscrew the cover part at the bottom of the phone (USB connector side)
    • 7 small Philips-head screws to remove, plus a bit of black adhesive tape
    • Once the cover is removed, unplug the flex cable
  7. Moto G30 screen replacement, Unglue display cable: step 8, image 1 of 1
    • Detach the display flex cable from the back of the chassis
  8. Moto G30 screen replacement, Remove the screen: step 9, image 1 of 3 Moto G30 screen replacement, Remove the screen: step 9, image 2 of 3 Moto G30 screen replacement, Remove the screen: step 9, image 3 of 3
    • Once the battery is gone, it is possible to add some heat to help detach the screen
    • I could not properly unglue with a cutter blade on the side. My technique is simpler and more brutal: I pushed the display away from the connector hole, with a rigid tool.
  9. Moto G30 screen replacement, Clean up the frame: step 10, image 1 of 1
    • Remove the glass shards still glued around the frame
    • Put some gloves on, because glass shards are dangerous!
  10. Moto G30 screen replacement, Optional: test phone: step 11, image 1 of 2 Moto G30 screen replacement, Optional: test phone: step 11, image 2 of 2
    • Replug the battery pack
    • Test battery voltage on the testpoint at the left of the connector (you will find ground anywhere on the metal chassis). Voltage must be between 3.6 and 4.2 V.
    • You can also test the motherboard with a Linux-based computer
    • Unglue the screen-USB-motherboard flex cable from your broken screen, and replug the bottom USB board with the top motherboard
    • Turn on phone with Power On + Up buttons
    • Plug it to the computer with an USB-C cable
    • Type "lsusb" in a shell
    • If you can read something like "22b8:XXXX Motorola PCS moto g(30)", congratulations: your motherboard still lives
  11. Moto G30 screen replacement, Order replacement screen: step 12, image 1 of 2 Moto G30 screen replacement, Order replacement screen: step 12, image 2 of 2
    • Once your phone has been successfully torn down and tested, it is time to order the replacement screen
    • The part will cost you around 15-20€. You can find it here for instance
    • While waiting for your order, don’t forget to store your parts and small screw properly
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
93%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Eve Redero
2,205 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 69
All Time: 142
