Introduction
In the process of using Casio calculator, if you see the figures appear blurred, the battery is weak. Now you need to replace the battery for the computer, because otherwise it will give incorrect calculation results. How to replace the Casio computer battery is very simple, you refer to the following article to learn how to replace the Casio computer battery at home.
Removing the battery is the way to replace a new battery. You can remove our old battery to new battery.
Before you use the calculator after replacing, operate the key: Shift+9(Reset), press 3 then press =.
