Carrera Mario Copter Rotor Blade Replacement
  1. Carrera Mario Copter Rotor Blade  Replacement, Rotor Blade: step 1, image 1 of 1
    • Using the JIS #00 screwdriver, hold the rotor blade still and unscrew the 4.762mm screw in the center of the blade.
  2. Carrera Mario Copter Rotor Blade  Replacement: step 2, image 1 of 1
    • Lift the screw out and set it aside.
    • Lift the rotor blade out.
    • Be sure to place the rotor blades properly for stable flight. With the quadrocopter facing you, the front rotor blades should be red with blade A on the right and B on the left. The rear rotor blades should be blue with blade B on the right and A on the left.
Marissa Espino
101 Reputation
1 Guide authored
UW Tacoma, Team S1-G6, Rose Fall 2017 Member of UW Tacoma, Team S1-G6, Rose Fall 2017
UWT-ROSE-F17S1G6
4 Members
10 Guides authored
One Comment
Hi. How i can buy the rotor blade
Ainul Abd Rahim - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 1,463
