Introduction
All of the internal surfaces, especially the conductive metal pieces, need to be clean and well kept in order for the microphone to function at its best.
Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
Create a mild cleaning solution by mixing a few drops of dish soap and water in a cup.
Using a detailing brush and the solution, gently brush the pins and inside walls of the microphone.
After cleaning the faceplate and reassembling the microphone, it should work at its maximum potential.
2 Comments
Thanks for the join. I’m checking out the Shure Sm-58 repair. Thanks for the info
Hi I checked the solder on the wires inside the microphone and it still does not work. Any other ideas?
