Capresso Perfectea 260 Motherboard Replacement
  1. Capresso Perfectea 260 Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • First, take the base of the device and flip it over.
  2. Capresso Perfectea 260 Motherboard Replacement: step 2, image 1 of 2 Capresso Perfectea 260 Motherboard Replacement: step 2, image 2 of 2
    • Remove the four 12 mm Phillips #2 screws surrounding the base then lift the bottom half of the base to expose the circuit boards inside the device.
  3. Capresso Perfectea 260 Motherboard Replacement: step 3, image 1 of 1
    • Remove the two 7.5 mm Phillips #2 screws holding in the motherboard
  4. Capresso Perfectea 260 Motherboard Replacement: step 4, image 1 of 1
    • Unplug the wire going into the side of the motherboard
  5. Capresso Perfectea 260 Motherboard Replacement: step 5, image 1 of 2 Capresso Perfectea 260 Motherboard Replacement: step 5, image 2 of 2
    • Use the metal spudger to cut open the rubber covering the latch where it clamps onto the copper tab.
    • Unplug wire at heating element by first using the metal spudger to push the latch in and then pushing it out.
    • Be careful when unplugging the wire as if it is done too forcefully it can damage the connection and make it difficult to connect a new motherboard
  6. Capresso Perfectea 260 Motherboard Replacement: step 6, image 1 of 1
    • Lift the motherboard out of the device
Rohin Chander
101 Reputation
1 Guide authored
Cal Poly, Team 6-17, Maness Spring 2015 Member of Cal Poly, Team 6-17, Maness Spring 2015
CPSU-MANESS-S15S6G17
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 238
