Capresso Perfectea 260 Lid Replacement
  1. Capresso Perfectea 260 Lid Replacement, Lid: step 1, image 1 of 1
    • Lift the lid of the Perfectea
    • Remove the two 12mm Phillips #2 screws located at the brim of the pot.
  2. Capresso Perfectea 260 Lid Replacement: step 2, image 1 of 3 Capresso Perfectea 260 Lid Replacement: step 2, image 2 of 3 Capresso Perfectea 260 Lid Replacement: step 2, image 3 of 3
    • Adhesive tape is left holding the lid to the glass pot.
    • Use the spudger for this step.
    • With one hand, firmly grip the lid while designating your other hand to wedge the spudger between the lid and the glass pot.
    • Working from the outside to the inside, gently pry the adhesive tape from the glass pot, detaching the lid.
Kenji Anzai
588 Reputation
4 Guides authored
Cal Poly, Team 6-17, Maness Spring 2015 Member of Cal Poly, Team 6-17, Maness Spring 2015
CPSU-MANESS-S15S6G17
4 Members
6 Guides authored
One Comment
This guide applies to the Capresso H2O kettle too. Thanks for the guide.
Giovanni Ciriani - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 659
