Canon Selphy CP720 Cooling Fan Replacement
  1. Canon Selphy CP720 Cooling Fan Replacement, Cooling Fan: step 1, image 1 of 2 Canon Selphy CP720 Cooling Fan Replacement, Cooling Fan: step 1, image 2 of 2
    • Remove the four 8mm Phillips #1 screws from the bottom of the printer.
  2. Canon Selphy CP720 Cooling Fan Replacement: step 2, image 1 of 1
    • Gently lift the top half of the printer off its base
    • A data ribbon attaches the two halves, so don't pull hard and keep the two halves close together.
  3. Canon Selphy CP720 Cooling Fan Replacement: step 3, image 1 of 3 Canon Selphy CP720 Cooling Fan Replacement: step 3, image 2 of 3 Canon Selphy CP720 Cooling Fan Replacement: step 3, image 3 of 3
    • Remove the side panel by lifting it out.
  4. Canon Selphy CP720 Cooling Fan Replacement: step 4, image 1 of 2 Canon Selphy CP720 Cooling Fan Replacement: step 4, image 2 of 2
    • Unplug the fan from the circuit board by gently pulling on the wire connector at the base of the port.
    • Do not tug on the wires. Slowly increasing force as you pull is the best way to detach the wires.
  5. Canon Selphy CP720 Cooling Fan Replacement: step 5, image 1 of 1
    • Unscrew the two 8mm Phillips #1 screws from the fan.
    • Remove the fan from the panel.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 309
