Canon PowerShot SX150 IS Buttons Replacement
  1. Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: step 1, image 1 of 3 Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: step 1, image 2 of 3 Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: step 1, image 3 of 3
    • Locate the battery cover on the bottom of the camera.
    • Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
    • Remove batteries.
  2. Canon PowerShot SX150 IS Buttons Replacement, Buttons: step 2, image 1 of 3 Canon PowerShot SX150 IS Buttons Replacement, Buttons: step 2, image 2 of 3 Canon PowerShot SX150 IS Buttons Replacement, Buttons: step 2, image 3 of 3
    • Remove the two, 2mm screws from the top of the screen. Using the J000 screwdriver.
    • Remove the 3, 5mm screws on either side of the camera. continue to use the same screwdriver from step 1.
  3. Canon PowerShot SX150 IS Buttons Replacement: step 3, image 1 of 1
    • Remove the two, 4mm screws from the bottom of the camera. Continue using the same screwdriver from step 1.
  4. Canon PowerShot SX150 IS Buttons Replacement: step 4, image 1 of 1
    • Remove back plate from the camera and locate the orange button plate to the right of the screen.
  5. Canon PowerShot SX150 IS Buttons Replacement: step 5, image 1 of 3 Canon PowerShot SX150 IS Buttons Replacement: step 5, image 2 of 3 Canon PowerShot SX150 IS Buttons Replacement: step 5, image 3 of 3
    • Once the back plate is removed. Locate the buttons to the right of the screen.
    • Using the tweezers carefully lift up the tabs connecting the buttons to the button plate.
    • After lifting the tabs the buttons should come right off, then replace with the new button.
One Comment
Where do you buy replacement buttons/parts. Canon offers service but i don’t see parts?
robert jones - Reply
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 8
All Time: 538
