Canon EOS 20D Secondary Control Board (C-Board 010) Replacement
  1. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove the eyepiece cap: step 1, image 1 of 2 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove the eyepiece cap: step 1, image 2 of 2
    • Pull up on both sides of the the eyepiece cap. It should come off with little pressure.
  2. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove screws from under the eyepiece cap: step 2, image 1 of 1
    • Remove the two screws hidden under the viewfinder eyepiece cap.
  3. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove hidden screw and other visible screw: step 3, image 1 of 3 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove hidden screw and other visible screw: step 3, image 2 of 3 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove hidden screw and other visible screw: step 3, image 3 of 3
    • Peel off the rubber grip on the back by grasping one of the corners and pulling it away from the camera body.
    • Once removed, a hidden screw is revealed.
    • Remove both screws from the rear of the camera.
  4. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove bottom screws: step 4, image 1 of 1
    • Remove the two indicated screws from the bottom of the camera.
  5. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Lift and remove the rear panel: step 5, image 1 of 3 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Lift and remove the rear panel: step 5, image 2 of 3 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Lift and remove the rear panel: step 5, image 3 of 3
    • When lifting the panel, make sure not to lift it too high, since you'll run the risk of tearing the cable, or damaging the connector on the board.
    • Flip the lock on the flex cable connector up with a spudger.
    • The front panel should pop off, now that the cable has been disconnected.
    • When reassembling the device, make sure to insert the left side of the front panel first, since it has a small lip that needs to fit under the left part of the camera case.
  6. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Disconnect all the labeled cables: step 6, image 1 of 3 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Disconnect all the labeled cables: step 6, image 2 of 3 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Disconnect all the labeled cables: step 6, image 3 of 3
    • Disconnect all the indicated connectors by opening their latches.
    • Remove the flex cable that connects the logic board to the secondary control board.
    • Pull the small green connector out of its socket. Be careful when removing it, as it is possible to tear the tiny wires running into the connector.
    • Disconnect the two hidden connectors under the top connector indicated in pink.
    • Disconnect the third hidden connector.
  7. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove the secondary control board: step 7, image 1 of 2 Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove the secondary control board: step 7, image 2 of 2
    • Remove the three screws from the edges of the board.
    • Flip the board up and out so that the ground connection can be unscrewed.
2 other people completed this guide.
Alec M
1,309 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 1,149
