Canon EOS 20D CF Card Slot Replacement
  1. Canon EOS 20D CF Card Slot Replacement, Remove the eyepiece cap: step 1, image 1 of 2 Canon EOS 20D CF Card Slot Replacement, Remove the eyepiece cap: step 1, image 2 of 2
    • Pull up on both sides of the the eyepiece cap. It should come off with little pressure.
  2. Canon EOS 20D CF Card Slot Replacement, Remove screws from under the eyepiece cap: step 2, image 1 of 1
    • Remove the two screws hidden under the viewfinder eyepiece cap.
  3. Canon EOS 20D CF Card Slot Replacement, Remove hidden screw and other visible screw: step 3, image 1 of 3 Canon EOS 20D CF Card Slot Replacement, Remove hidden screw and other visible screw: step 3, image 2 of 3 Canon EOS 20D CF Card Slot Replacement, Remove hidden screw and other visible screw: step 3, image 3 of 3
    • Peel off the rubber grip on the back by grasping one of the corners and pulling it away from the camera body.
    • Once removed, a hidden screw is revealed.
    • Remove both screws from the rear of the camera.
  4. Canon EOS 20D CF Card Slot Replacement, Remove bottom screws: step 4, image 1 of 1
    • Remove the two indicated screws from the bottom of the camera.
  5. Canon EOS 20D CF Card Slot Replacement, Lift and remove the rear panel: step 5, image 1 of 3 Canon EOS 20D CF Card Slot Replacement, Lift and remove the rear panel: step 5, image 2 of 3 Canon EOS 20D CF Card Slot Replacement, Lift and remove the rear panel: step 5, image 3 of 3
    • When lifting the panel, make sure not to lift it too high, since you'll run the risk of tearing the cable, or damaging the connector on the board.
    • Flip the lock on the flex cable connector up with a spudger.
    • The front panel should pop off, now that the cable has been disconnected.
    • When reassembling the device, make sure to insert the left side of the front panel first, since it has a small lip that needs to fit under the left part of the camera case.
  6. Canon EOS 20D CF Card Slot Replacement, Disconnect all the labeled cables: step 6, image 1 of 3 Canon EOS 20D CF Card Slot Replacement, Disconnect all the labeled cables: step 6, image 2 of 3 Canon EOS 20D CF Card Slot Replacement, Disconnect all the labeled cables: step 6, image 3 of 3
    • Disconnect all the indicated connectors by opening their latches.
    • Remove the flex cable that connects the logic board to the secondary control board.
    • Pull the small green connector out of its socket. Be careful when removing it, as it is possible to tear the tiny wires running into the connector.
    • Disconnect the two hidden connectors under the top connector indicated in pink.
    • Disconnect the third hidden connector.
  7. Canon EOS 20D CF Card Slot Replacement, Remove the secondary control board: step 7, image 1 of 2 Canon EOS 20D CF Card Slot Replacement, Remove the secondary control board: step 7, image 2 of 2
    • Remove the three screws from the edges of the board.
    • Flip the board up and out so that the ground connection can be unscrewed.
  8. Canon EOS 20D CF Card Slot Replacement, CF Card Slot: step 8, image 1 of 3 Canon EOS 20D CF Card Slot Replacement, CF Card Slot: step 8, image 2 of 3 Canon EOS 20D CF Card Slot Replacement, CF Card Slot: step 8, image 3 of 3
    • Open the connector for the CF slot.
    • Remove the screw that attaches the bottom of the CF slot.
    • Remove the two last screws attaching the top of the CF slot.
    • Remove the CF slot.
5 other people completed this guide.
Alec M
1,309 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 41
All Time: 2,040
