Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement
  1. Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement, Flex-Cable Aperture - Aperture Flex: step 1, image 1 of 2 Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement, Flex-Cable Aperture - Aperture Flex: step 1, image 2 of 2
    • Here is the problem with this camera and the needed replacement part is shown.
  2. Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement, Remove bayonet lock: step 2, image 1 of 2 Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement, Remove bayonet lock: step 2, image 2 of 2
    • The bayonet lock is mounted with four little screws. Remove them and mark them (like all other screws) and put them aside
    • The black insert is a plastic part and fixed with four clips from below. The most upper ring can be lifted a little bit on the opposite side of the contacts. By doing that, you can remove one or two clips from below to push out the black insert carefully.
    • Be especially carefully not to put too much tension on the flex-cable which connects the contact-strip with the PCB below!
    • The contact-strip itself is fixed with two very tiny PH0-Phillips-screws from the outer side. Please remove both of them and put them aside
  3. Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement, Remove circuit board: step 3, image 1 of 2 Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement, Remove circuit board: step 3, image 2 of 2
    • Now, remove all flex cables from the the PCB very carefully. There are several different ways of connections.
    • remove the screw which holds the PCB in place and remove the board afterwards
  4. Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement, Removing assembly for scales: step 4, image 1 of 1
    • now disassemble the assembly with the scale for focal length and distance.
  5. Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement, Remove Focus assembly: step 5, image 1 of 1
    • now remove the assembly for the manual focus
  6. Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement, Disassemble the cage: step 6, image 1 of 1
    • now, it gets a little bit tricky: the rails of the "cage" are guided by little pins. These are individually sized and have to go exactly where they were before. So be careful and document everything in detail
  7. Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement: step 7, image 1 of 1
    • Dismantle aperture plate and IS assembly
  8. Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement: step 8, image 1 of 1
    • Unsolder old flex cable for the aperture plate
  9. Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement: step 9, image 1 of 2 Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement: step 9, image 2 of 2
    • Resolder new cable for the aperture plate
Um Ihr Gerät wieder zusammenzubauen, befolgen Sie diese Anweisungen in umgekehrter Reihenfolge.
6 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
jensloewe
172 Reputation
1 Guide authored
2 Comments
Stimmt nicht ganz. Die “Collars” mit dem Kreuz sind exzentrische und justieren die Optik. Einfach reinschrauben wo´s mal war is nicht! Danach kann man das Teil in die Tonne kloppen oder dann für teures Geld zu Canon schicken.
Bitte unbedingt alle Bastelwütigen genau auf das hinweisen.
Was kann man tun? In der Regel ist immer einer von den dreien zentrisch; der kann bedenkenlos am gleichen Platz montiert werden. Vom Rest von jeder Seite genug Fotos machen und Markierunen anbringen WO genau das Kreuz war. Da geht´s eigentlich um´s Hunderstel. Wenn´s danach für den Hausgebrauch bei f8 ist… Also Zeit lassen, Linsengruppen nicht verdrehen usw.
Thomas Loebl - Reply
Jupp, da muss auf jeden Fall drauf hingewiesen werden. Wenn die exzentrischen Pins vorne an der Blenden/IS Einheit beim rauspulen auch noch verbogen werden, wars das ohnehin. So, wie in der Anleitung beschrieben, ist das leider eine Reparatur für die Tonne.
Patch -
Past 24 Hours: 3
Past 7 Days: 37
Past 30 Days: 178
All Time: 9,169
