CASIO fx-300ES Plus Scientific Calculator Battery Replacement
  1. CASIO fx-300ES Plus Scientific Calculator Battery Replacement, Battery: step 1, image 1 of 1
    • Turn off the calculator by pressing the [Shift] button.
    • Press the [AC][OFF] button.
  2. CASIO fx-300ES Plus Scientific Calculator Battery Replacement: step 2, image 1 of 1
    • Flip the calculator over so that the back panel faces forward.
    • Use a Phillips #0 screwdriver to remove the screw in the upper right corner.
    • If the screw is not unfastening, do not force it because it can strip the screw. If the screw is already stripped see the How to Remove a Stripped Screw guide.
  3. CASIO fx-300ES Plus Scientific Calculator Battery Replacement: step 3, image 1 of 1
    • Remove the battery cover.
  4. CASIO fx-300ES Plus Scientific Calculator Battery Replacement: step 4, image 1 of 1
    • Insert the spudger in the available slot in the middle of the right side.
    • Use the spudger to pry out the battery.
    • Be gentle when removing the battery to avoid damaging it.
  5. CASIO fx-300ES Plus Scientific Calculator Battery Replacement: step 5, image 1 of 2 CASIO fx-300ES Plus Scientific Calculator Battery Replacement: step 5, image 2 of 2
    • Place the new LR44 alkaline battery into the calculator.
    • Be sure that the + sign is at the bottom.
  6. CASIO fx-300ES Plus Scientific Calculator Battery Replacement: step 6, image 1 of 1
    • Reattach the battery cover.
    • Insert the screw for the battery cover using a Phillips #0 screwdriver.
  7. CASIO fx-300ES Plus Scientific Calculator Battery Replacement: step 7, image 1 of 1
    • Reset the calculator by pressing [ON].
    • Press the [shift] button.
    • Press the [9] [CLR] button to clear the data.
    • Press the [3][ALL] button option.
    • Press [=] [yes] button to agree.
    • Press [AC] key to reset.
You have now successfully replaced a Casio FX-300ES battery.
2 other people completed this guide.
Maha
255 Reputation
1 Guide authored
One Comment
Below is a detailed video showing the battery replacement process.
https://youtu.be/I7pR-_Ra5W8
Tomatoman - Reply
Past 24 Hours: 20
Past 7 Days: 142
Past 30 Days: 720
All Time: 29,572
