Briggs and Stratton 675 Series Repair Air Filter Replacement
  1. Briggs and Stratton 675 Series Repair Air Filter Replacement, Air Filter: step 1, image 1 of 1
    • Make sure the the engine is off and the spark plug wire is removed and away from the spark plug before beginning.
    • Use a Flathead #4 screw driver to remove the 40mm screw that holds the air filter case in place.
  2. Briggs and Stratton 675 Series Repair Air Filter Replacement: step 2, image 1 of 1
    • Use your hands to pull the air filter case out of the hinge at the bottom.
  3. Briggs and Stratton 675 Series Repair Air Filter Replacement: step 3, image 1 of 1
    • Simply remove the air filter with your hands.
6 other people completed this guide.
Taichi Nakahara
397 Reputation
1 Guide authored
Cal Poly, Team 6-31, Amido Winter 2015 Member of Cal Poly, Team 6-31, Amido Winter 2015
CPSU-AMIDO-W15S6G31
4 Members
15 Guides authored
2 Comments
Good information, although it didn't resolve my issue. Thanks for sharing
all2thegoodpromo - Reply
This is a power wash motor water will not come out
hdoggett Doggett - Reply
Past 24 Hours: 5
Past 7 Days: 67
Past 30 Days: 287
All Time: 19,555
