Breville BKC600XL Spring Replacement
  1. Breville BKC600XL Spring Replacement, "Bottom" Black Shell Piece: step 1, image 1 of 3 Breville BKC600XL Spring Replacement, "Bottom" Black Shell Piece: step 1, image 2 of 3 Breville BKC600XL Spring Replacement, "Bottom" Black Shell Piece: step 1, image 3 of 3
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Breville BKC600XL Spring Replacement, "Top" Black Shell Piece: step 2, image 1 of 1
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Breville BKC600XL Spring Replacement, Silver Casing: step 3, image 1 of 3 Breville BKC600XL Spring Replacement, Silver Casing: step 3, image 2 of 3 Breville BKC600XL Spring Replacement, Silver Casing: step 3, image 3 of 3
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
  4. Breville BKC600XL Spring Replacement, Spring: step 4, image 1 of 1
    • Identify the spring and the hook its attached to.
    • Carefully remove the spring.
Antonio
120 Reputation
6 Guides authored
Cal Poly, Team 1-3, Propen Fall 2012 Member of Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 1,798
