Bose Quiet Comfort 35 II Audio Jack Connector Replacement
  1. Bose Quiet Comfort 35 II Audio Jack Connector Replacement, Audio Jack Cable Connector: step 1, image 1 of 1
    • Take off ear cushion pad using the plastic opening tool. Pry until you notice the seam of the ear cushion separates from the plastic tabs.
  2. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: step 2, image 1 of 3 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: step 2, image 2 of 3 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: step 2, image 3 of 3
    • Take off the ear cover by peeling off the glue with hands.
  3. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: step 3, image 1 of 2 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: step 3, image 2 of 2
    • Remove the two 7-millimeter silver screws from the inside by using the Phillips #000 screwdriver to disconnect the back cover.
  4. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: step 4, image 1 of 2 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: step 4, image 2 of 2
    • Remove the two 5-millimeter silver screws attaching the earphones to the headband using the Phillips #000 screwdriver.
  5. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: step 5, image 1 of 2 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: step 5, image 2 of 2
    • Detach the earpiece form the band using the flat part of the metal spudger.
    • Slide the joint at the end of the headphone band out to release ear piece.
  6. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: step 6, image 1 of 2 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: step 6, image 2 of 2
    • Detach the silver cover on the outside of the headset using the spudger.
    • Pry until you hear a distinct pop; this indicates the cover has separated from its base.
  7. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: step 7, image 1 of 2 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: step 7, image 2 of 2
    • Solder off the ribbon cable from the driver near the cable connector port to detach it.
  8. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: step 8, image 1 of 2 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: step 8, image 2 of 2
    • Replace the cable connector with spare driver/audio jack combo.
    • Optional: desolder the five audio jack posts seen here, and replace individual audio jack.
kssexton
463 Reputation
3 Guides authored
IUPUI, Team 1-2, Harley Fall 2023 Member of IUPUI, Team 1-2, Harley Fall 2023
IUPUI-HARLEY-F23S1G2
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 64
All Time: 361
