Bose NC700 Battery Replacement
  1. Bose NC700 Battery Replacement, Remove the ear pad from the left cup: step 1, image 1 of 1
    • Use a plastic card to remove the ear pad from the left cup. Slide the card into the slot and make a rotating motion.
  2. Bose NC700 Battery Replacement, Remove the screws: step 2, image 1 of 1
    • Remove the fabric cover and remove the four screws using a Torx TR6 screwdriver.
  3. Bose NC700 Battery Replacement, Disconnect the cable and remove battery: step 3, image 1 of 1
    • Carefully disconnect the flex cable.
    • Cut the three battery cables. Cut one wire at a time to avoid short circuits!
  4. Bose NC700 Battery Replacement, Remove battery: step 4, image 1 of 1
    • The battery is glued to the case. Use a knife to carefully cut off the battery. Take care not to damage the battery!
    • Be sure to clean any adhesive residue from the case.
  5. Bose NC700 Battery Replacement, Remove the shell from the battery.: step 5, image 1 of 1
    • Remove the shell from the old battery.
  6. Bose NC700 Battery Replacement, Remove the controller from the old battery: step 6, image 1 of 1
    • Cut the controller from the old battery.
  7. Bose NC700 Battery Replacement, Remove the controller from the new battery: step 7, image 1 of 1
    • Cut the controller from the new battery.
  8. Bose NC700 Battery Replacement, Solder the new battery to the old controller: step 8, image 1 of 3 Bose NC700 Battery Replacement, Solder the new battery to the old controller: step 8, image 2 of 3 Bose NC700 Battery Replacement, Solder the new battery to the old controller: step 8, image 3 of 3
    • Solder the new battery to the old controller. Observe the polarity!
  9. Bose NC700 Battery Replacement, Wake up the controller: step 9, image 1 of 2 Bose NC700 Battery Replacement, Wake up the controller: step 9, image 2 of 2
    • Measure the voltage at the controller pins. You will most likely get 0 volts. It is necessary to wake up the controller.
    • Use any battery controller. Solder the battery to the battery terminals on the controller.
    • Charge the battery through the external controller for 5-10 minutes.
    • Disconnect the charging cable and verify that the battery is energized. Charge the battery to 4 volts (if required).
    • Unsolder the external controller.
  10. Bose NC700 Battery Replacement, Attach the controller: step 10, image 1 of 1
    • Attach the controller to the battery with tape.
  11. Bose NC700 Battery Replacement, Solder the battery: step 11, image 1 of 1
    • Solder the battery. Use heat shrink tubing or duct tape to insulate the soldering area.
    • Your headphones will turn on when you solder the battery. Turn off the headphones.
  12. Bose NC700 Battery Replacement, Place the battery in the bottom of the cup: step 12, image 1 of 1
    • Place the battery in the bottom of the cup.
To reassemble the unit, follow the instructions in reverse order.
4 other people completed this guide.
Special thanks to these translators:
ru en
100%
Andrew Yakunin is helping us fix the world! Want to contribute?
Start translating ›
Andrew Yakunin
427 Reputation
1 Guide authored
7 Comments
Thank you, very useful and money saving
Petra Ehlers - Reply
Happy to help.
Andrew Yakunin -
Cool! how did you knew the battery was the issue? Did you have the red/white blinking LED issue on your headphones? I got that issue since the end of last year, and am not quite sure if it is a software or hardware related issue. Would love to fix it but indeed couldnt find any official replacement batteries or anything.
Headphone - Reply
Yeah, I had the same problem. I think there's a bug in these headphones. If the battery is very low, the headphones think there is no battery and don't charge it.
Andrew Yakunin -
my man. thanks
Ron Tahan - Reply
Past 24 Hours: 23
Past 7 Days: 136
Past 30 Days: 569
All Time: 1,945
