Blackberry Curve 8330 Track Ball Replacement
  1. Blackberry Curve 8330 Track Ball Replacement, Remove Back Cover: step 1, image 1 of 1
    • We did not have an actual back cover or battery for the phone we were given. Therefore, the first couple of steps will be without pictures.
    • Hold the phone with the back side facing you.
    • Press down on the silver tab towards the bottom end of the phone.
    • Carefully lift up the back casing to reveal the battery.
  2. Blackberry Curve 8330 Track Ball Replacement, Remove Battery: step 2, image 1 of 1
    • Put your finger on the top left corner of the battery and lift the battery up and out of its housing.
    • The phone should now look like this.
  3. Blackberry Curve 8330 Track Ball Replacement, Keyboard: step 3, image 1 of 1
    • Remove the two top screws using a T5 Torx screwdriver.
  4. Blackberry Curve 8330 Track Ball Replacement: step 4, image 1 of 2 Blackberry Curve 8330 Track Ball Replacement: step 4, image 2 of 2
    • Use a plastic opening tool to pry the edges of the bottom cover until it snaps loose.
    • The cover will now pull off easily.
  5. Blackberry Curve 8330 Track Ball Replacement: step 5, image 1 of 2 Blackberry Curve 8330 Track Ball Replacement: step 5, image 2 of 2
    • Use a plastic opening tool to pry between the front and back cover.
    • Start prying from wherever it is easiest to separate the silver and black plastic of the covers.
    • There are 5 securing clips on the front panel to disconnect.
    • Pry gently to prevent breaking the plastic clips when removing the front panel.
    • Once all the clips have been freed, the front cover will lift away from the phone.
  6. Blackberry Curve 8330 Track Ball Replacement: step 6, image 1 of 1
    • Lift the flexible keypad away from the device. It should come off easily.
  7. Blackberry Curve 8330 Track Ball Replacement: step 7, image 1 of 2 Blackberry Curve 8330 Track Ball Replacement: step 7, image 2 of 2
    • Use a T6 Torx Screwdriver to remove the four corner screws on the keyboard's housing.
    • Lift the keyboard frame away from the device.
    • There may be a small amount of adhesive at the bottom of the frame that needs to be pulled away.
  8. Blackberry Curve 8330 Track Ball Replacement, Track Ball: step 8, image 1 of 1
    • Use a plastic opening tool to pry the trackball housing from the keyboard housing.
  9. Blackberry Curve 8330 Track Ball Replacement: step 9, image 1 of 1
    • Remove the trackball from the silver trackball housing by hand.
Nhan Le
27 Reputation
1 Guide authored
Cal Poly, Team 14-11, Forte Spring 2012 Member of Cal Poly, Team 14-11, Forte Spring 2012
CPSU-FORTE-S12S14G11
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 5,325
