BlackBerry PlayBook Speaker Replacement
  1. BlackBerry PlayBook Speaker Replacement, Remove Back Panel: step 1, image 1 of 2 BlackBerry PlayBook Speaker Replacement, Remove Back Panel: step 1, image 2 of 2
    • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
    • There are clips that need to be released on all four sides of the device.
    • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
  2. BlackBerry PlayBook Speaker Replacement, Unscrew Left Speaker: step 2, image 1 of 1
    • Remove 1.55x.33mm Phillips screw from the metal frame.
    • Remove 1.5x4.25mm Phillips screw from speaker bar.
  3. BlackBerry PlayBook Speaker Replacement, Remove the Left Speaker Stickers: step 3, image 1 of 2 BlackBerry PlayBook Speaker Replacement, Remove the Left Speaker Stickers: step 3, image 2 of 2
    • Peel off the stickers holding the left speaker in place with a tweezer or by using your fingers
  4. BlackBerry PlayBook Speaker Replacement, Remove Left Speaker: step 4, image 1 of 2 BlackBerry PlayBook Speaker Replacement, Remove Left Speaker: step 4, image 2 of 2
    • Slide the left speaker bar out from its metal bracket.
  5. BlackBerry PlayBook Speaker Replacement, Unscrew Right Speaker: step 5, image 1 of 1
    • Remove both 1.5x4.25mm Phillips screws from the right speaker bar by using the Phillips Screwdriver.
  6. BlackBerry PlayBook Speaker Replacement, Remove Right Speaker: step 6, image 1 of 2 BlackBerry PlayBook Speaker Replacement, Remove Right Speaker: step 6, image 2 of 2
    • Lift the right speaker bar to remove it.
Nathan
661 Reputation
4 Guides authored
Cal Poly, Team 14-27, Maness Fall 2014 Member of Cal Poly, Team 14-27, Maness Fall 2014
CPSU-MANESS-F14S14G27
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 988
