Introduction
How to replace the LCD and reassemble the Blackberry 7105t
With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
The silver piece is not attached to the logic board in any way, and can be taken off by lifting it up with plastic opening tools.
With the screen facing you, you will be able to see a small grey plastic clip.
Use a plastic opening tool to unfasten the clip as shown.
After removing the original screen, keep the logic board facing you the way it was.
Take the new screen and slip the flexible piece of connecting circuitry under the grey plastic flap that you pried up in step 10.
Push it gently but firmly until it does not move any further to the left, then close the grey flap.
After this, the screen can be pushed down and clicked back into place.
To reassemble the phone, reverse instructions.
Handle the screen carefully as it is fragile.
Push the screen gently but firmly until the connecting cable does not move any further to the left, then close the grey flap.
Push the screen down until it clicks into place.
Be sure to check that the white clips are aligned on each side before continuing.
