Black and Decker BL3000S button panel replacement
  1. Black and Decker BL3000S button panel replacement, Blender Base: step 1, image 1 of 2 Black and Decker BL3000S button panel replacement, Blender Base: step 1, image 2 of 2
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Black and Decker BL3000S button panel replacement: step 2, image 1 of 1
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Black and Decker BL3000S button panel replacement: step 3, image 1 of 2 Black and Decker BL3000S button panel replacement: step 3, image 2 of 2
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Black and Decker BL3000S button panel replacement: step 4, image 1 of 1
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Black and Decker BL3000S button panel replacement: step 5, image 1 of 1
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  6. Black and Decker BL3000S button panel replacement, Circuit Board: step 6, image 1 of 1
    • Once you have the base removed, the circuit board should be clearly visible inside.
  7. Black and Decker BL3000S button panel replacement: step 7, image 1 of 2 Black and Decker BL3000S button panel replacement: step 7, image 2 of 2
    • Remove the four screws located on the circuit board.
    • Two are on the left side.
    • Two are on the right side.
  8. Black and Decker BL3000S button panel replacement: step 8, image 1 of 1
    • Remove the following soldered connections with a soldering iron:
    • Motor wires
    • Power cord wires
  9. Black and Decker BL3000S button panel replacement: step 9, image 1 of 1
    • Lift the circuit board straight up to remove it from the base.
  10. Black and Decker BL3000S button panel replacement, Buttons: step 10, image 1 of 1
    • Once the circuit board has been freed from its screws it can be moved out of the way to gain access to the buttons.
    • A single screw must be removed from the top as shown.
  11. Black and Decker BL3000S button panel replacement: step 11, image 1 of 1
    • Push firmly from the outside of the blender on the face of the buttons to pop it out of its locked position.
  12. Black and Decker BL3000S button panel replacement: step 12, image 1 of 2 Black and Decker BL3000S button panel replacement: step 12, image 2 of 2
    • Provided is a front and a back view of a functioning button frame from the BL3000S.
    • Check for cracks, bends, debris, or missing extentions and fastens.
Austin Abernathy
18 Reputation
1 Guide authored
Cal Poly, Team 6-34, Regan Fall 2012 Member of Cal Poly, Team 6-34, Regan Fall 2012
CPSU-REGAN-F12S6G34
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 31
All Time: 2,393
